MiniSphere
A handheld Las Vegas Sphere!
We're shrinking the Las Vegas Sphere down to something you can hold in your hand! Each MiniSphere is 75mm in diameter and has 1080 LEDs, powered by a 7000mAh battery pack. They have an IMU for motion-based animations, and a UWB radio so they can sense where they are relative to each other.
  • 1080 LEDs in the Palm of Your Hand!
    OK Design03/13/2024 at 04:29 0 comments
    We're starting to finalize some of the bigger pieces of this project, so we're excited to start sharing our progress! We've got the geometry and LED arrangement set, now we're testing our electrical design and getting started on writing some animations. Here's what we've been up to!
    Hardware
    To test out our electrical design before we jump into form factor MiniSpheres, we decided to start with a development board to test all the subsystems and components, and to characterize the system.
    We got the development boards made and assembled by PCBWay (www.pcbway.com), big thanks to them for sponsoring the PCBAs! We've used PCBWay for fabrication and assembly a bunch over the years, and their quality and speed is hard to beat. Our boards came perfectly assembled with no issues, and in no time!
    The heart of the system is a Quarto DWM3001C module, which has an nRF52 microcontroller and an ultra-wideband radio. The nRF52 is responsible for interfacing with everything from the IMU, to the battery charger, to the addressable LEDs on the outside.
    The development board has the following subsystems:
    • Quarvo Module (BLE/UWB)
    • IMU
    • Battery Charger
    • BMS
    • LED Boost Converter (Li-Ion → 5V)
    • 3V3 Buck Converter
    • Hall Effect Sensor
    • Level Shifter for the LEDs
    • USB-C (Programming/Debug/Charging)
    Finally, the development board has a single panel of LEDs. The full spheres will have 10 of these each!
    We've fully tested and validated the hardware design and apart from some small bodge wires, we are ready to fabricate the form factor control boards!
    Mechanical
    The main goal of this project is to shrink the Las Vegas sphere as much as we can, while keeping as much functionality as possible. We experimented with different geometries and diameters, and different arrangements and densities of LEDs, balancing that with other requirements like battery life. We landed on a V3 geodesic sphere with 180 faces, 75mm in diameter, with 6 LEDs per face. That's a total of 1080 LEDs, powered by seven 18350 Li-Ion cells in parallel.
    One sphere will have 10 flexible PCB panels of LEDs, soldered together to cover the sphere in LEDs. The flexes wrap around a subframe structure that supports them while protecting the internal components. Each flex has small contacts on either side to chain power and data from one flex to another, and similar pads on the back that lets us tap into those signals if we need to.
    Each hemisphere of the subframe has locating features to align the flexes, and to align from one hemisphere to the other. We broke the sphere up into the smaller LED panels due to the manufacturing cost of one large flex.
    Below is a cross section of the sphere:
    And here you can see how the hemispheres are split, which lets us open the sphere up for maintenance and debugging. Ultimately, we'll add an outer shell to protect the whole assembly and diffuse the light from the LEDs.
    Battery Safety
    Since these spheres will be in the hands of our friends, family, and strangers alike, we want to make sure it's safe to handle. When not handled properly, the Li-Ion batteries can easily turn these into lack-luster grenades. To mitigate this, we're only charging the battery back to 4.1V (instead of the typical 4.2V), and we have a BMS to protect the pack from short circuits, as well as under and over voltage conditions.
    Simulator
    We started with a Python simulator to help explore LED arrangements and spacing, and to have an easier way to test out ideas for animations and patterns on the spheres. It uses VPython for the 3D rendering and geometry, which makes it super simple to get some shapes on the screen.
    The simulator is the source of truth for some of the physical aspects of the sphere. For one, it prints out the relative LED positions that the CAD uses to place the LEDs on each face. The simulator also knows the ordering of LEDs in the chain, so it can produce the mapping from LED indices to their orientations in space, which ultimately drives the animations....
View project log
blecuafrederic wrote 10/08/2024 at 10:06 point
DO for juggle
R. Scott Coppersmith wrote 07/23/2024 at 12:26 point
Very cool, I need one!
