Hackaday.io Hackaday.io
Sign up Log in
Reconfigurable electronics & IO extension
Reconfigurable electronics -- easy to use for Arduino, Raspberry & Co. with a preprogrammed FPGA board.
julianJulian
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2 comments
7 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 5
    • View all
  • Instructions 0
  • Discussion 2
  • The 2017 Hackaday Prize
View Gallery
562
2
7
9
Team (1)
  • julianJulian
Join this project's team
  • Library
  • Project webpage
  • INSTAGRAM
  • Twitter
  • Facebook
hardware
ongoing project
FPGA arduino kickstarter 2017HackadayPrize
Related lists
2017 THP: Digi-Key Parts
Hackaday Prize Entries using Digi-Key parts
This project is submitted for
  • Hackaday.com Tip Line
  • Design your concept
  • Best Product
This project was created on 01/20/2017 and last updated 9 years ago.
Description
Reconfigurable electronics, and less mess with jumper cables? Need a chainable UART / SPI / I2C IO extender with LOTS of pins? Is it okay if it can output PWM signals as well?
The iolinker FPGA board connects any two pins (signals up to 29.56 MHz) for you, on the fly. Ideal for prototyping, self-testing and designs with many IOs.
Developing time critical embedded software and prototyping embedded solutions a lot -- sometimes with custom PCBs, sometimes without -- I noticed how much time is wasted rewiring digital signals in prototype setups; and in companies, it is costly, too, often wasting time of both a software and a hardware engineer simultaneously.
I wanted a solution that simplifies plug'n'play designs, creates flexibility and keeps my wiring in software -- version controlled. This FPGA project has been on my mind for years, and now I got some help to make it come true.
This is a preprogrammed, low-cost Lattice FPGA board + Arduino adapter.
Project Logs
Collapse
  • Kickstarter funding succeeded
    Julian • 05/18/2017 at 17:30 • 0 comments
    The Kickstarter funding succeeded a while ago!
    An improved version of the iolinker board is shipping next week. It's IO mapping is slightly cleaned up and it has a MicroUSB connector for powering it. More comfy to use and test :)
    With the shield adapter and our library on GitHub things are really neat to use now -- via UART, SPI or I2C:
  • We are on Kickstarter!
    Julian • 02/15/2017 at 22:38 • 0 comments
    We are now on Kickstarter and already had a great first day! http://kck.st/2kOJ15v
  • Complete introduction video
    Julian • 02/15/2017 at 22:36 • 0 comments
  • FPGA board soon on Kickstarter
    Julian • 02/09/2017 at 02:13 • 0 comments
    Hi,
    we are going live on Kickstarter next Tuesday! 3pm CEST (= 5am PST).
  • Teaser videos
    Julian • 02/03/2017 at 20:24 • 0 comments
View all 5 project logs
Log In/Sign up to comment
Sign up with Github
OR
Julian wrote 05/18/2017 at 13:11 • point
antti.lukats, thanks for your comment. You are correct about that value not making much sense. Internal oscillator clock is 66.5 MHz, so jitter and duty cycle not accounted for we should end up with ~31.6 MHz safe LNK frequency (i.e. 5.5% clock derivation and 50% Shannon-Nyquist subtracted). Not sure how to include the jitter / duty cycle part accurately? I was under the impression that was included in the synthesis constraints.
Antti Lukats wrote 05/17/2017 at 13:21 • point
you say the LNK connection can be used to signals max 29.56mhz (that is 59.12 Mbit/s) but internal oscillator i 5.5% accuracy, also you must count for some jitter and duty cycle distorion, so the limit you set in datasheet, should be either higher or lower than 29.56MHz, the exact number is for sure wrong. If you want to mux 29mhz then you must use 88.67Mhz internal oscilator clock and system clock for the multiplexer, in that case you have at least (hopefully) clock edge per 29mhz signal you mux. But if it works for 29.56, it works equally well for 29.9MHz :) so there is problem in the datasheet.
An affordable AND useful FPGA board for all. Finally.
Project Owner Contributor
Crystal Board - FPGA Platform for All
chrisChris
Making tools that allow for effortless creation of bootloaders and Arduino support packages for custom SAMD-based boards
Arduino support for custom SAMD board
alexander-kirillovAlexander Kirillov
'FleaFPGA Uno' Starter board
valentin-angelovskiValentin Angelovski
Powerful One Stop Arduino Compatible Development and Prototyping Board with ATmega128 at the Core.
The Winkel Board
rishiRishi
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Reconfigurable electronics & IO extension", please tell us the reason.
Send message
Remove Member
