How it started...
I started this project with a fully functional TRS-80 Model II, including the stock keyboard. The first thing I did was get a copy of the TRS-80 Model II Technical reference manual to grab as much info as possible about the keyboard interface.
Next I intercepted the keyboard interface output lines directly from the keyboard card:
And captured the keystroke on the scope:
Then it was time to hookup the Arduino to enable some bit-banging:
Originally, I started writing the code literally from scratch, including the shaping of the waveforms themselves. Who knew that there was already a very handy ShiftOut function in the Arduino library? (Not me, that's who!) 😉 Fortunately I did some learning and was able to get a matching DATA and CLOCK signal that was (almost) perfect!
I later figured out (through trial and error) that the double characters were from push the signals through too quickly. Once I slowed it down to "typing speed" it seemed to clear up that problem.
USB Host Ghost
This is where things got weird. I purchased an Arduino compatible USB Host Shield from Amazon. The build quality was "ok" but I couldn't get it to work. After scouring several forums (and soldering the appropriate power jumpers) I found out that there's known issue with the wrong driver chips being used on these boards...the only fix was to replace one of them - they are surface mount - I don't have the tools, skills...or maybe just the patience...time to go in another direction!
Enter the ESP32
I made the switch from Arduino to ESP32, more specifically the ESP32 S3 WROOM. I also moved to the Visual Studio Code IDE. It took a few evenings to get the hang of it...I'm still an Arduino fan but this ESP32 is powerful stuff indeed!
A couple of evenings in and I was already able to get the ESP32 to process USB HID keystrokes...I was on my way again!!!
I ported my old Arduino code over to the ESP32, and managed to produce a duplicate of what the TRS-80 Model is looking for. (Note that M2_USB_Keyboard.c code is attached to the project for download.)
* @DiPDoT - NEW M2_SHIFTOUT FUNCTION used to bitbang the DATA and CLOCK
* @params: dataPin : GPIO of DATA
* clockPin : GPIO of CLOCK
* bitOrder : MSBFIRST or LSBFIRST
* val : Output Key Code (ASCII)
void M2_shiftOut(uint8_t dataPin, uint8_t clockPin, uint8_t bitOrder, uint8_t val) {
uint8_t i;
// Model II - Only send the value if the busyPin is HIGH
if(gpio_get_level(BUSY_PIN)) {
// Model II - Start DATA high (Don't know if this is needed but just matching the spec for now)
gpio_set_level(dataPin, HIGH);
for(i = 0; i < 8; i++) {
if(bitOrder == LSBFIRST)
gpio_set_level(dataPin, !!(val & (1 << i)));
else
gpio_set_level(dataPin, !!(val & (1 << (7 - i))));
ets_delay_us(SO_DELAY); // Stalls execution for #uS
gpio_set_level(clockPin, HIGH);
gpio_set_level(clockPin, LOW);
// Model II expects line to be high
// Add the "notch" to the end of the data cycle
gpio_set_level(dataPin, LOW);
Because the ESP32 has a max input of 3.3V to the GPIOs, I also needed to use a bi-directional level converter. Fortunately these are cheap and plentiful, and I was almost ready for the big test!
I used a female DIN connector this time so I don't even need to pop the top off of the Model II.
Testing
The new board is capturing keystrokes and bit-banging them to the Model II perfectly! I haven't seen a single double character...
DiPDoT (Brian)
