A project log for M8B 2.0
Magic 8 Ball + User Guide 2.0
nelithzederdelleNelithzederdelle 05/16/2024 at 10:590 Comments
Ball
More tests for DF Player
- "get started" example from the "DFRobotDFPlayerMini.h" library
- this one :
- more from : DFPlayer Mini Mp3 Player - DFRobot Wiki
- and several other tries from random YouTube videos I found
But this was not conclusive.
So I moved to the subject of the Hall effect sensor.
Instruction Book
Hall effect sensor
The sensor we ordered is : 3524405C  (AH3524)
the objective is for a LED to turn on when the magnet is far/not here, and turn off when the magnet is very close.
However, the sensor we ordered has the reverse effect: The LED turns on when the magnet is close to the sensor. Similar to the first example shown in this video :
2 Basic Project with Hall effect Sensor (youtube.com)
So the solution we found is to use a NPN transistor.
Quest to find the transistor : just started.
Ball
We also worked on the ball itself, preparing the patreons and cutting the pieces in the cardboard.
The goal is to cover each piece of carbon with a piece of fabric and put them all together like the paper prototype.
We also planned to have a "door" to open the ball.
