Beautify Your Bash Prompt
A simple tweak for Linux enthusiasts to elevate their terminal experience.
Public Chat
0 followers
The purpose of this is to customize the terminal by adding some features and nice colors.
Features:
  • Current date and time.
  • Full current working directory.
  • Exit status of the previous command.
  • Lots of space to write bash commands.
  • Clear separation of previous commands.
  • Execution time of the previous command.
.bash_prompt
The custom bash prompt. Copy this file to your home directory.
bash_prompt - 2.83 kB - 03/14/2024 at 20:57
Download
  • 1
    How to install the bash prompt
      Check for Existing .bash_prompt:
      First, you need to check if there's already a .bash_prompt file in your home directory. Execute the following command:
    ls ~ -a | grep .bash_prompt
      Rename Existing '.bash_prompt':
      If you find an existing .bash_prompt and want to keep it as a backup, rename it using:
    mv ~/.bash_prompt ~/.bash_prompt_OLD
      Download and Move New .bash_prompt:
      Download the bash_prompt file from my project post. After downloading, move the file to your home directory and rename it to .bash_prompt:
    mv ~/Downloads/bash_prompt ~/.bash_prompt
      Update .bashrc:
      Now, you need to update your .bashrc file to ensure it uses the new .bash_prompt. Open .bashrc with nano:
    nano ~/.bashrc
      At the end of the file, add the following line to source the .bash_prompt:
    source ~/.bash_prompt
      Save the file by pressing Ctrl-S and exit nano with Ctrl-X.
      Apply the Changes:
      To apply the changes and use the new bash prompt, source your .bashrc file:
    source ~/.bashrc
      Set A Dark Background:
      Visual Studio has a pleasantly dark background that we all love. The hex code for it is: #1F1F1F. Set the color by pressing the button with horizontal lines on it ⟶ Preferences ⟶ Unnamed ⟶ Colours ⟶ Background.
View all instructions
