What you need are just:
Note: detect the soil moisture/air humidity/temperature and broadcast every 60 minutes.
This gateway is composed of ESP32S3 4G LTE A7670 module and A LoRa radio expansion
Note: LoRa communication needs the sender& receiver to work at the same frequency. The frequency of the LoRa Soil Moisture Sensor is 915MHz, so the frequency of the LoRa Expansion Board needs to be 915MHz as well.
