ThingSpeak Is The Open IoT Platform With MATLAB Analytics.
- Register and log in to your account
- Define the parameter you want on the Channel page and save it.
- On the API keys page, you can find the API key used to write the data, and you can see an example of an API request on the right.
- By accessing the URL of the write channel, you can modify the parameters and the result you can view at "Private View" page.
