sanded with 240 sanding paper, without epoxyfirst layer epoxy, let dry second layer epoxy, a little bit overfilledrest of the housing also treated with epoxysanded again from 120 (carefully only for the overfilled display) to 240 to 400 to 800 sanding paper
