Unfortunately I had to cancel plans to be able to use a Pi Zero with Modufix. I had to do this as the limited capabilities the zero has at the moment, with only 512MB of ram it would have been impossible to port android to it. Also getting a display to work with HDMI was also going to be a challenge for a sub $200 display. I know this may be bad for some people who already had a pi zero on hand to start the project, but without it version 6 and onwards will have a much cleaner and better design.
- Shambler
