Before jumping in and buying the Camry, first I wanted to reproduce the high voltage and high current measurements in the US Department of Energy document. So, I need to measure ~300 V for the hybrid battery pack, and about 130 Amps for discharge, and -100 Amps for charging.
First, I need a big resistor divider that can withstand that. A single resistor will break down, so I'm going to try with the snake of 1210 resistors so that no one resistor gets a large voltage. Testing will be done on my regular AC, because I have a split plug, I can get 240 RMS, or 339.4 V pkpk between the phases...
![](https://cdn.hackaday.io/images/3759711710650979331.png)
Here is the isolated ADC test board - ready to be battery powered so completely floating for the high voltages and transients.
![](https://cdn.hackaday.io/images/8600681710651096191.png)
For measuring current, I was going to try a TI DRV5053 placed right beside a current carrying conductor, and just measure the tiny field surrounding the cable...
![](https://cdn.hackaday.io/images/3030571710651181469.png)
