11Step 11
Use some pliers to pry open the tabs acting as a strain relief on the cable jacket
12Step 12
Remove the metal casing
Note the pin-out (Counter clockwise in this case: black, white, green blue, red)
Cut the wires
13Step 13
Slide on the metal casing BEFORE soldering on the new pins
14Step 14
Solder the wires to the appropriate pins
15Step 15
Use pliers to squeeze the metal tabs onto the cable jacket
16Step 16
Place the metal tab into the corresponding cutout on the black plastic
Line up the metal casing and pull it over the pins
17Step 17
Thread in the screw and you're done
18Step 18
