Simultaneously, we also explored the development of a hand-adaptable clip designed to securely hold the knife. This design is envisioned to be realized through 3D printing technology. To assess user experience, we crafted an initial prototype using thermoplastic shavings, moldable when heated with hot water. Through this method, we successfully shaped the plastic to achieve the desired form. However, initial testing revealed ongoing challenges in usability. As such, our focus will be on forging ahead with this project to achieve substantial progress.
Attached is a photograph of the prototype for reference.
![](https://cdn.hackaday.io/images/9334031711616660954.jpeg)
![](https://cdn.hackaday.io/images/6410091711616661176.jpeg)
![](https://cdn.hackaday.io/images/3151671711616669787.jpeg)
![](https://cdn.hackaday.io/images/8869631711616674278.jpeg)
