In this project, we will build a tiny internet clock connected to your wifi to get time from NTP servers.
Supplies
- Seeed Studio XIAO ESP32C3
- 0.91 Inch 128x32 OLED LCD Display
- USB C cable
- Connecting wires
Step 1: Modeling in Autodesk Fusion 360
I used Fusion 360 for planning and designing this
[upload all design files]
Step 2:3d printing
We also need to 3d print some parts for this project. i printed mine with my Anycubilc Kobra 2 neo 3d printer All files are available at Step 1
Step 3: uploading code to xiao
I always like to upload the code to the microcontroller before assembly. I am using Arduino IDE for flashing the code.
You need to change 2 thing in order to use this code
- Your wifi SSID and Password
- GMT offset
GMT offset is need to mention in second in code for example your GMT offset it +5.30 hrs of you convert it in to second it will be 5.5 x 3600 = 19800 seconds
The code
#ifdef ESP32
#ifdef ESP32
#include <WiFi.h>
#else
#include <ESP8266WiFi.h>
#endif
#include <time.h>
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
Adafruit_SSD1306 display = Adafruit_SSD1306(128, 32, &Wire, -1);
const char* ssid = "SSID";
const char* password = "Password";
int GMTOffset = 19080; //Replace with your GMT Offset in seconds
int daylightOffset = 0; // Replace with your daylight savings offset in seconds
void setup() {
Serial.begin(115200);
if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) {
Serial.println(F("SSD1306 allocation failed"));
for(;;);
delay(2000);
display.clearDisplay();
display.setTextSize(1);
display.setCursor(0,0);
display.setTextColor(WHITE);
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED) {
delay(1000);
Serial.println("Connecting...");
Serial.println("Connected to Wi-Fi!");
configTime(GMTOffset, daylightOffset, "0.in.pool.ntp.org","time.nist.gov");
void loop() {
time_t rawtime = time(nullptr);
struct tm* timeinfo = localtime(&rawtime);
Serial.print("Time: ");
Serial.print(timeinfo->tm_hour);
Serial.print(":");
Serial.print(timeinfo->tm_min);
Serial.print(":");
Serial.println(timeinfo->tm_sec);
display.setTextSize(3);
display.setCursor(0,10);
display.print(timeinfo->tm_hour);
display.print(":");
if( timeinfo->tm_min <10)
display.print("0");
display.print(timeinfo->tm_min);
display.setTextSize(2);
display.setCursor(90,15);
display.print(":");
if( timeinfo->tm_sec <10)
display.print("0");
display.print(timeinfo->tm_sec);
display.display();
delay(1000);
Step 4: wiring diagram
This is the wiring diagram
Step 5: assembly and wiring
Step 1
Connect all 4 wires between OLED and Xiao
Step 2
Glue the oled into the font panel
Step 3
Stick the antenna on the top of the 3d print
Step 4
Place the xiao into the 3d print make sure the USB port is visible on the back glue it with a glue gun. Also connect the antenna into the board
Step 5
Close the front cover by glueing it
test
Please connect the USB cable to power the device, which will automatically update the time.
gokux
Debinix
Jonathas Barbosa
Peter
Junior
Hi! I thought you might like to know I made your Tiny Internet Clock project! https://imgur.com/a/hx7ZlzZ Thank you so much for sharing. It came out great.
