Introduction
This clock has great sentimental value to me from my childhood as I grew up with it. Unfortunately, the clock accuracy started drifting severely. I have to set the time daily as it goes out-of-sync up to 10 minutes each day.
Many nostalgic things to like about this clock. It has an FM radio which I listened to daily as a kid. I always loved how it looked ahead of its time with the large digital font. Growing up, this clock piqued my interest in the rising field of digital electronics.
In this project, I will share my journey to retrofit it to give it a new life. Here I shall automate it to synchronize to internet time periodically.
![](https://cdn.hackaday.io/images/8988591711435151068.jpg)
Teardown
Let's tear down the device to understand how it works. Firstly, the model is a Philips AJ 3380/00 Digital Radio Clock. After unscrewing, we immediately see the large components such as the speaker, AC transformer, seven segment display and mechanical buttons.
![](https://cdn.hackaday.io/images/124751711435151783.jpg)
I continued disassembling it until the main circuit board. At this point, I stopped tearing it down further as the circuit board was secured quite tightly with the plastic clips. Nevertheless we have enough information to plan the possible points of modification.
![](https://cdn.hackaday.io/images/3559371711435155166.jpg)
We see that the circuit board is dated March 1999. (Just about my age!). We also know that the clock IC controller is a LM8562. The circuit board matches very closely to the application circuit in the LM8562 datasheet.
![](https://cdn.hackaday.io/images/8276401711550470861.png)
Points of modification
The goal is to automate time synchronization. We can use a microcontroller to do the following:
- read the current time, and
- adjust the time
To adjust the time, the clock provides two buttons: Up and Down. I soldered some wires here to access it later.
![](https://cdn.hackaday.io/images/2526421711435151573.jpg)
An analog switch IC can be used to simulate the button press.
However for reading the current time, it is slightly complex. The only way I can think of is to read it off the seven segment outputs. Also be aware that there is display multiplexing involved.
Understanding LM8562 display multiplexing
From the LM8562 datasheet, we also see the sample application schematic. From the schematic, the display is driven by two cycles of multiplexing. AC voltage directly from the transformer is used for display multiplexing.
I probed the supply pins of the display with an oscilloscope. This is the complementary 9V peak-peak 50Hz sine waves used for multiplexing. (Note: my grid supply is 50Hz where I live).
[Danger!] AC voltage is involved. Oscilloscope grounding must be done with care. From the schematic, the ground is referenced to the negative terminal of the battery. Hence I attached the oscilloscope ground clip to the battery connector.
![](https://cdn.hackaday.io/images/8566961711435153257.jpg)
- On the left image, we see a segment lit up for only one segment (one multiplex-cycle is negative below GND and the other is above GND).
- On the right image, we see a segment lit up for both multiplex-cycles (the entire waveform is above GND).
![](https://cdn.hackaday.io/images/4529781711435150201.jpg)
Using a simple opamp comparator, I can detect which phase (of the two multiplexing cycles) it is in, and also whether a segment is lighted up (High/Low). I also added an optocoupler as a convenient way to do level shifting (between the 9V analog to the 3V3 digital microcontroller).
![](https://cdn.hackaday.io/images/5383321711435143445.jpg)
Reverse Engineering Display Pinout
Now all that is left is to find out which pins correspond to which segment.
I shorted each pin to GND to determine which of it belongs to which segment. A lighted segment will turn off when shorted to GND.
After all the reverse engineering, I came up with the following pinout.
![](https://cdn.hackaday.io/images/6800081711346031238.png)
PCB Design Circuit
Putting it all together, I designed a PCB with the following major items:
- WiFi-enabled ESP8266 module was chosen as the microcontroller.
- MCP23017 I/O Port Expander to read all the 16 input pins of the connector.
- CD4052B analog switch to simulate the button press.
- LM358 Opamp and 4N25 Optocoupler for the comparator logic.
- LM1117-3.3V regulator for the microcontroller power.
![](https://cdn.hackaday.io/images/5794171711550822396.png)
The schematic PDF is attached below.
Soldering and Testing Circuit
This is how the board looks like after soldering
![](https://cdn.hackaday.io/images/5717481711554417929.jpg)
One mistake: The optocoupler DIP packages were longer than usual and could not fit in consecutively. Thankfully, they fit in after using some pin sockets in a staggered pattern
![](https://cdn.hackaday.io/images/7196661711435153969.jpg)
After writing a demo program in Arduino, I was able to detect the segments on each phase of the multiplexing cycle. The segments can be converted into the 4 digits shown on the display.
![](https://cdn.hackaday.io/images/7087291711435156850.jpg)
The last part is to add the code to retrieve the synchronized time, and the NTPClient Arduino library was used.
Final Demo
In this video demo, I show the clock being toggled between 12:34 and 23:45. The LED indicators on the PCB show the status of the time synchronization process. The sample code is attached below.
![](https://cdn.hackaday.io/files/1953838359266272/post_main.gif)
