Due to an error in logic and knowledge, we decided to use a small motor that was handed to us. This small motor was supposed to power the input shaft of the differential gear. Due to the length of the gear and the low amount of torque, the motor could not generate enough power to turn the differential gear which has admittedly several places that create friction. So using a saw we cut 2/3 of the shaft off and added a stronger motor which turns slower.
This was the first try of the input shaft. It wobbled too much and it wasn't stable. The wood holding the motor and shaft was not high enough to reach the main gear of the differential gear which is why we tried to add higher leverage to the already bad construction.
