One of my goals is to make it easier to work on projects. Tiny components (surface mount parts, tiny screws, small labeling, etc.) present a challenge and as a result I keep trying different methods and devices to help me view them better and hence make working with them easier.
Some of what I've tried so far:
- Simple Magnifying Glasses – hand
held and fixed
- need to be very close to object being viewed
- Reading glasses (various
magnifications)
- higher the magnification → closer you need to be to what you are viewing
- Binocular Microscope
- works quite well but still need to be bent over the scope
- a movable stage would improve its ease of use
- USB Microsope
- not much experience but they can have a bit of a delay (what you see can be a fraction of a second behind what is happening at the moment).
- Video Scope – NTSC camera,
lenses and composite display
- works reasonably well
- may be able to improve by moving view screen lower and angling it
I'm testing and trying out other optical and video approaches to find an efficient and cost effective solution.
Tom Meehan
Benjamin Blundell
Timescale
Dylan
David Troetschel
A little late to the party but I found this article that I think will be very helpful if you decide to move forward (if you haven't already) with the Galilean loupes. I'm thinking om making some myself. http://www.sunbeamdental.com/loupes_dentistry_formatted.pdf
