Fourth Trial
A project log for Design for disability (Fitness glove)
by Junggi Ko, Theo Yang
ko3369ko3369 03/26/2024 at 15:080 Comments
Date. 26. mar. 2024
At the beginning of the class, we talked about different problem that Youssrah can find, like the wrist problem for exemple when she start the work out, weight can prevent blood circulation. There is also the problem to with the hand because the hole is too big.
prototype of a glove
she gave us feedback about a finger part.
■ her difficultness of using fitness equipment.
 1) Her fingers is weak to hold heavy things.
 2) The adhesive part of the device is difficult to use
3) The fingers on both ends are not easy to fold and unfold
her needs of using fitness equipment.
1) She wants to improve her arms strength.
2) She wishes the exercise equipment were comfortable to wear.
3) She needs a part to put her thumb in to tighten the string to adjust her arm properly.
also we thought about weight part. we will make a hole in weight and put magnets .
It can attach on a glove.
weight.
weight 3D
That’s the reason we are waiting for the Velcro and the magnet to have a better view for the next session
