Date. 26. mar. 2024
At the beginning of the class, we talked about different problem that Youssrah can find, like the wrist problem for exemple when she start the work out, weight can prevent blood circulation. There is also the problem to with the hand because the hole is too big.
she gave us feedback about a finger part.
■ her difficultness of using fitness equipment.
1) Her fingers is weak to hold heavy things.
2) The adhesive part of the device is difficult to use
3) The fingers on both ends are not easy to fold and unfold
■ her needs of using fitness equipment.
1) She wants to improve her arms strength.
2) She wishes the exercise equipment were comfortable to wear.
3) She needs a part to put her thumb in to tighten the string to adjust her arm properly.
also we thought about weight part. we will make a hole in weight and put magnets .
It can attach on a glove.
