One of the most challenging current bugs is adding collaborators.
This is supposed to be done by typing "@" followed by a persons username in this box:
However, the drop down menu often only shows one or two names to select. and there is no search function or anything like that. There also seems to be different behaviors for it across browsers.
CriptasticHacker
