So there appears to be a nasty video-embed bug, when using the built-in video link share button.
With this bug, the video image embeds itself in random parts of the post, behind other images even - and can move text around too. I'ts pretty nutty.
example of the video embed bug
One workaround I have found is to simply the embed URL and adjust the viewing box to a smaller size. In this case, 720 x 405 seems to work. It also helps to use the HTML markup version of your post (icon <> located in upper right)
work-around for embedded videos.
A note of caution though, don't add video embeds until the very end in your post. It will save you some cleanup work and headaches.
CriptasticHacker
