Raspberry Pi Pico M-Bus Master HAT:
Usage:
Features:
- M-Bus (meter bus) Master
- powered by an external 9..30V DC voltage (36V for the MBUS will be generated internally from this voltage)
- up to 6 unit loads can be powered
- communication with Pico via UART0 or UART1
- isolated interface
- can be combined with the Raspberry Pi Pico
Raspberry Pi Pico M-Bus Slave HAT:
Usage:
Features:
- M-Bus (meter bus) slave node
- based on the TSS721 M-Bus Transceiver IC from Texas Instruments
Lithium ION
tongdee9070
