A/C, Furnace Plenum Zone Valve
ESP32 module controls plenum zone valve when plenum air pulls room temperature away from set point.
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
ESP monitors 2 OneWire temperature probes. One in the plenum. One in the room. If the plenum air is too warm or too cold (ie: will pull room temperature away from the set point) the ESP32 commands a hobby servo to close the valve.
