Windows AudioController
A device to switch audio devices in Windows
A device to switch audio devices (e.g. headset < - > speakers) in Windows, change the volume and mute the microphone.
The AudioController is based on a Arduino (wemos D1 mini) which communicates with a Windows Powershell script via serial connection. In addition to the CH340 driver, no other drivers are necessary. No native USB is used.
All scripts and other ressources can be found in this project.
HowTo
1. install Cmdlet on Windows PC
https://github.com/frgnca/AudioDeviceCmdlets
2. install CH340 (WemosD1 mini) driver
https://www.wemos.cc/en/latest/ch340_driver.html
3. copy "AudioController.ps1" script to your prefered path
4. get COM port for your WemosD1 mini via Powershell (or Windows Device Manager)
Powershell: Get-WMIObject Win32_SerialPort | Select-Object DeviceID,Description
-> change SerialPort Number in "AudioController.ps1" in config section
5. start powershell script via windows scheduled job
#name
soundcontroller
----> *high privileges
----> *hidden
#trigger
at logon
----> *delay 15sec.
#actions
start program
#program/script
C:\Windows\System32\WindowsPowerShell\v1.0\powershell.exe
#arguments -> !!  you have to adjust  the path of the script  !!
-noexit -ExecutionPolicy Bypass -WindowStyle hidden -File C:\bastel\audio_controller\AudioController.ps1
#start in
ESP PINOUT
Display:
SCL:    D1 (GREEN CABLE)
SDA:    D2 (ORANGE CABLE)
Rotary:
LFT:    D6 (GREEN CABLE)
RGT:    D5 (ORANGE CABLE)
Buttons:
MIC:    D3 (VIOLET CABLE)
SWC:    D7 (YELLOW CABLE)
LED's:    D8 (RED CABLE)
Flash Firware on Arduino
flash your Wemos D1 mini with code (available for download in this repo) with Arduino IDE
AudioController.ps1
Windows code
ps1 - 5.37 kB - 07/10/2024 at 07:58
Download
soundcontroller.xml
Windows scheduled job example for import (you have to adjust your user and the path of the script)
XML - Extensible Markup Language - 3.57 kB - 04/03/2024 at 18:02
Download
firmware_0.3.ino
Arduino code
ino - 32.01 kB - 04/03/2024 at 18:00
Download
stl.rar
housing stl
x-compressed - 1.82 MB - 04/03/2024 at 18:00
Download
  • 1 × Rotary encoder EC28A1550401
  • 1 × Wemos D1 Mini
  • 1 × 20mm Bearing NSK 6804 RS 492
  • 1 × Display 0,96 Inch OLED Display Modul SSD1306 Development Kits, Boards and Systems / Intellectual Property Cores
  • 2 × 6x6x5mm Panel PCB Momentary Tactile switch
View all 4 project logs
