With the PrintAirPipe - 360° Intake Segment, it is possible to direct the air inside the PrintAirPipe pipe system to the outside or to draw air from the outside into the inside of the pipe system.
The ventilation openings in the segment can be closed or opened either manually using a small lever or automatically.
The firmware of the control electronics is based on ESPHome and can therefore be integrated into many SmartHome systems such as HomeAssistant.
The STL files are available at: https://nerdiy.de/en/product-2/printairpipe-360-intake-segment-3d-printable-stl-files/
