With the PrintAirPipe - BambuLab X1 connection set you can collect the exhaust air from your BambuLab X1 3D printer and forward it using the PrintAirPipe system. This means that the exhaust air from the 3D printer can, for example, be directed outside or further filtered before being fed into the ambient air.
This set currently contains two adapters that direct the exhaust air outlet to the 50mm PrintAirPipe system or the 80mm PintAirPipe system.
The STL files are available at https://nerdiy.de/de_de/produkt/printairpipe-bambulab-x1-anschluss-set-3d-druckbar-stl-dateien/
![](https://cdn.hackaday.io/images/9876381718310831511.jpg)
![](https://cdn.hackaday.io/images/4873381718310927934.jpg)
