The servo valve segment of the #PrintAirPipe system can be used as a controllable valve.
The valve blade is controlled by an MG90 servo. Thanks to the built-in ESP32, the servo can be controlled via WiFi or the touch sensor on the housing.
The LED shows the states open (green) and closed (red). The firmware is based on #ESPhome and the files are available on my blog nerdiy.de
STLs & ESPHome Configuration:
