LED Matrix V1
My first LED matrix.
0 followers
I have had an ongoing project to make a LED matrix and I have finally got my design printed on a PCB.
This ongoing project consists of a PCB powered off an Arduino.
As you can see from the image there is a wire cut off and you may even think why not use a GPIO pin coming out of the board instead, the reason is because there was meant to be a GPIO pin there but we made some mis-calculation's on sizes so we couldn't get a GPIO pin to fit the wires we had so we just soldered one one making things very fragile.
My name is Harrison and I am only in year 5 so some of this may be a bit simple but still I hope you like it!
If you would like to make one please have a look at the instructions here on the project.
I have also added some sample code but that will mean that you need to plug your wires the same way as I do so have a look at the image bellow also listed in the gallery and instructions.
Thank you
HACKEREXAMPLE.ino
The example code
ino - 589.00 bytes - 04/09/2024 at 09:03
Download
Led Matrix V1 gerber.zip
The Gerber PCB file
Zip Archive - 17.59 kB - 04/06/2024 at 07:33
Download
Led_Matrix_V1.kicad_pcb
The Kicad PCB file
kicad_pcb - 89.11 kB - 04/06/2024 at 00:31
Download
  • 9 × LED 1x1x0.15mm Fiber Optics / Emitters
  • 9 × Resistor 1x1x0.15mm
  • 6 × GPIO Note: Extremely small and I had problems with how small it was.
  • 1
    Downloading the design
    Via Hackaday Download the Kicad file.
  • 2
    Get it printed
    Use a company Eg: JLCPCB and add the file to the company's website then follow the prompts to order it.
  • 3
    Buying the parts
    Have a look at the components I used and order them from somewhere like Digikey .
View all 5 instructions
