- The "TFT_eSPI" library was created created when Squareline exports the project file, we need to modify the "Users_Setup.h" file of it, because every development board has different screen drivers IC, The ESP32-S3 1.28" use the GC9A01 as drivers IC, So define this driver.
Define GC9A01_DRIVER, and define the pixel width and height in portrait orientation for GC9A01
#define GC9A01_DRIVER
#define TFT_WIDTH 240
#define TFT_HEIGHT 240 // GC9A01 240 x 240
Then set the drive pin according to the schematic diagram
#define TFT_MOSI 13 // In some display driver board, it might be written as "SDA" and so on.
#define TFT_SCLK 14
#define TFT_CS 15 // Chip select control pin
#define TFT_DC 21 // Data Command control pin
#define TFT_RST 11 // Reset pin (could connect to Arduino RESET pin)
#define TFT_BL 45 // LED back-light
In Section 3. Define the fonts that are to be used here. We chose a variety of fonts to prevent them from being used without initializing them
#define LOAD_GLCD // Font 1. Original Adafruit 8 pixel font needs ~1820 bytes in FLASH
#define LOAD_FONT2 // Font 2. Small 16 pixel high font, needs ~3534 bytes in FLASH, 96 characters
#define LOAD_FONT4 // Font 4. Medium 26 pixel high font, needs ~5848 bytes in FLASH, 96 characters
#define LOAD_FONT6 // Font 6. Large 48 pixel font, needs ~2666 bytes in FLASH, only characters 1234567890:-.apm
#define LOAD_FONT7 // Font 7. 7 segment 48 pixel font, needs ~2438 bytes in FLASH, only characters 1234567890:-.
#define LOAD_FONT8 // Font 8. Large 75 pixel font needs ~3256 bytes in FLASH, only characters 1234567890:-.
//#define LOAD_FONT8N // Font 8. Alternative to Font 8 above, slightly narrower, so 3 digits fit a 160 pixel TFT
#define LOAD_GFXFF // FreeFonts. Include access to the 48 Adafruit_GFX free fonts FF1 to FF48 and custom fonts
// Comment out the #define below to stop the SPIFFS filing system and smooth font code being loaded
// this will save ~20kbytes of FLASH
#define SMOOTH_FONT
The touch panel driver is CST816S, so it need to call the touch function of CST816S.
void my_touchpad_read(lv_indev_drv_t *indev_driver, lv_indev_data_t *data)
uint16_t touchX = 0, touchY = 0;
bool touched = false; // tft.getTouch( &touchX, &touchY, 600 );
if (!touch.available())
data->state = LV_INDEV_STATE_REL;
else
data->state = LV_INDEV_STATE_PR;
/*Set the coordinates*/
touchX = touch.data.x;
touchY = touch.data.y;
data->point.x = touchX;
data->point.y = touchY;
USBSerial.print("Data x ");
USBSerial.println(touchX);
USBSerial.print("Data y ");
USBSerial.println(touchY);
initial the TFT_BLK, touch and ADC pins
pinMode(TFT_BLK, OUTPUT);
digitalWrite(TFT_BLK, 1);
pinMode(ADC_INPUT_1, INPUT);
touch.begin();
Modify the landscape orientation. The default value is 3. You need to change it to 0
tft.begin(); /* TFT init */
tft.setRotation(0); /* Landscape orientation, flipped */
Get the value of ADC, let the value of ui-Arc1/2/3 be changed with the output voltage of Mabee_Slide Potentiometer
int adc = analogRead(ADC_INPUT_1);
long int adc_percent = adc * 100 / 4096;
lv_arc_set_value(ui_Arc1, (int)adc_percent);
lv_arc_set_value(ui_Arc2, (int)adc_percent);
lv_arc_set_value(ui_Arc3, (int)adc_percent);
