A movable platform with Home Assistant.
The platform begin to move when I open the HA_MOTER DC Motern and stop automatically when it touch the terminal at the edge.
And when I click the HA_MOTER DC Moter, on the pop-up page, I can control the platform direction of movement and speed of movement.
1.Install the printout on the slide rail
2.Install the 2 collision switches for position limiting on the printout
3.Install the DC Motor for Home Assistant_GA36Y-555 on the printout
4.Install the GT2 Timing Pulley on the DC Motor for Home Assistant_GA36Y-555
5.Install the Idler Pulley wheel on the printout
6.Pass the belt through the slide gap and around the idler and timing pulleys, securing it to V-Slot Gantry Kit - 20mm
1.V-Slot Gantry Kit - 20mm
2.Idler Pulley wheel
3.GT2 Timing Pulley
4.GT2 Belts
5.V-SloT Linear Rail
6.Assembly Hardware
7.Some components need to be printed by BambuLab printer,the 3d file you can click Here.
8.DC Motor for Home Assistant_GA36Y-555
9.AC/DC adaptor
