There are a few changes I made to the standard RunCPM. It is easier for me to describe them than fork a copy of Marcelo's code.
Since the Power LED connected to Pin 12, I added the following define:
#define POWLED 12
In setup() I added the following to light the Power LED:
pinMode(POWLED, OUTPUT); digitalWrite(POWLED, HIGH);
I also set the serial speed to 115,200:
Serial.begin(115200);
I altered loop() so the LEDs blink alternately after CP/M exits:
void loop(void) {
delay(500);
digitalWrite(POWLED, LOW);
delay(1000);
digitalWrite(LED, HIGH);
delay(500);
digitalWrite(LED, LOW);
delay(1000);
