SolSpot - A universal light sensor for solar tracker setups
A project log for Sunchronizer - Single or Dual Axis Solar Tracker
3D printable ESPHome based 400W Single or Dual Axis Solar Tracker
fabianFabian 04/24/2024 at 17:100 Comments
One thing is critical for proper and fast Solar Tracking: Measure the current lighting conditions. Therefore I designed my own Solar Tracking Sensor called "SolSpot" which you can see below.
Below you can see my (current) finale state of the SolSpot housing. In order to connect the individual components together in a (hopefully) waterproof manner, I use a sealing ring printed from TPU. This is inserted into the grooves provided and clamped between the components. The watertightness of the front panel was particularly important to me because the sensor electronics are located directly behind it.
CloseUp of a mounted SolSpot and GPS Sensor on the Sensor Dock on top of the Sunrchonizer prototype. So that both sensors can be mount in parallel the Sensor Bank is used as adapter plate.
CloseUp of the SolSpot sensor. The LED and brightness sensor per segment is visible.
Below you can see a picture of the circuit board installed in the SolSpot Housing. Four TSL2591 light sensors are installed on it, with which the brightness in the respective sensor element and thus the alignment/direction of the sun can be measured by comparing the brightness in the different segments. Next to each light sensor I also installed an SK6812 Side LED. This allows the sensor to carry out a simple functional test (for example at night) to ensure that the light sensors are still working correctly.  Many thanks to pcbway.com for assistance with this project by providing their PCB service.
For the light sensors I use a TSL2591. These are read out via the I2C bus. Unfortunately, these do not have an adjustable I2C address. That's why I read the individual sensors via a TCA9548 I2C multiplexer. With this IC, an I2C bus can be multiplexed to eight different buses. Additionally an ADXL345 acceleration sensor and a compass are also installed.
Top side of the SolSpot PCB. Bottom side is available below.
Close Up of one of the segments of SolSpot containing a TSL2591 brightness sensor and a SK6812 Side LED.
Protype view of the mounted SolSpot PCB in the Front part of the SolSpot Housing. The PCB is fixed by an M2 screw and (hopefully) protected by humidity via a TPU based sealing "ring".
Bottom side of the SolSpot PCB. Including a little whoopsie (missing reset pull-up) that I fixed manually.
