Sunchronizer Update: S2 and D2 Are Here
A project log for Sunchronizer - Single/Dual Axis Solar Tracker
3D printable ESPHome based 400W Single or Dual Axis Solar Tracker
fabianFabian • 03/26/2026 at 11:33•0 Comments
Quick project update: after the first generation (S1/D1), I now have the 2nd generation variants ready and running:
Both versions are 3D-printable, ESPHome-based, and built for practical real-world use, not just bench demos.
S2 is the lower-complexity option with solid gains over static mounting. D2 adds azimuth tracking and is the best-performing variant for maximum daily yield.
I’m also publishing regular measurement series and analysis reports from real operation. The short version of the results so far:
Measurement overview and linked daily reports: https://github.com/Nerdiyde/Sunchronizer/blob/main/docu/measurements/MEASUREMENT_OVERVIEW.md
If there’s interest, I can post a follow-up with a direct S2 vs D2 build comparison (mechanics, BOM differences, and recommended setup path).
If you want to support me by building one: The STL files are available to buy here:
