Assembly & final surprise
A project log for SWAP ARCADE
The project consists of building a portable mini arcade with two displays. IPS round with lens & IPS 4&quo
srblondeSrBlonde 09/30/2024 at 11:090 Comments
I finally started putting the console together. Everything was going great until I went to connect the controller. At some stage of the design I had to expand the space I had measured for the controller. I have to redesign and print the three central pieces of the case again.
