Genesis
A project log for Print your own PCBs with Laser/CNC/Chemicals
Technique to build high quality PCBs in minutes. Also, compare different methods the resolution and ease of use.
100dollarhacker100dollarhacker 04/18/2024 at 01:250 Comments
It started few years ago when I wanted to build some device it started with a breadboard then it was time to shrink it
This thing is a giant leap, although it was really hard to work with this material
Now I tried building my own using a nail polish/marker and some chemical to etch the copper away
The result was ok but I couldn't reproduce easily and the main problem was the size of wire which with this 'technology' was about 2mm.
