Foxie CardClock 2.0
A delightfully pixelated, programmable WiFi analog+digital clock... the size of a credit card
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
Starting from
has orders / reviews
Ships from
This is the Foxie CardClock 2.0, a certified open-source (https://certification.oshwa.org/us002055.html), ESP32C3-powered, WiFi-enabled, RTC-havin', super-capacitor havin', analog+digital, RGB LED-laden, clock. It is the successor to the CardClock 1.0 (https://hackaday.io/project/181839-foxie-cardclock) and is based on the Foxie Clock 2.0 (https://hackaday.io/project/187511-foxie-clock-20).
- Feature rich firmware (https://github.com/foxieproducts/fcos)
- 5-way joystick
- 3 rings of 12 LEDs which are used as an analog clock displaying Hours, Minutes and Seconds.
- A 17x11 LED matrix also displays the time digitally and allows configuration
- Light sensor for a smooth brightness experience
- Expandability (QWIIC and 8-pin expansion)
- Time can be set manually or if on WiFi, syncs NTP time every 3 hours
- Onboard RTC with super-capacitor backup, keeps time while unplugged for more than 2 days
- Onboard ESP32-C3-MINI with WiFi/BLE
- Built-in f/w updates from github
