The CanHobby ATTiny10-LED is a minimal development board for the ATtiny10 MCU from MicroChip. It is designed to be used on a breadboard and has a single on-board LED connected to B1. It should be noted that later revisions of the ATTiny10-LED board have a solderpad on the bottom to enable the LED.
My grateful thanks to JLCPCB for making the process of designing and fabrication/assembly of my ATtiny boards so easy.
Everyone knows how to write an Arduino blink sketch but the ATTiny10 is a little different. Due to it's limited (could I say non-existent RAM) and Flash memory, conventions such as digitalWrite() do not exist. This sketch will illustrate the use of "Register Programming" which is at a lower level, just one step above assembler.
The Boards Package used in this example is ATtinycore10 from Technoblogy. The Boards Manager URL to add to the Arduino IDE preferences dialog is:
http://www.technoblogy.com/package_technoblogy_index.json
I am actually including 4 different methods to blink the LED.
- "Normal" - Write High - delay - Write Low Loop
- Using the "Toggle" feature available on limited AVR MCUs.
- Using the Timer with Output Compare GPIO.
- Using Timer interrupts to make a "heartbeat" dimmer.
"Normal" method
#include <util/delay.h>
#define B1 2
void setup() {
DDRB |= B1; // Set bit #1 to 1 to enable GPIO1 as OutPut
void loop() {
PORTB |= B1; // Set GPIO1 to HIGH
_delay_ms( 1000 ); // wait for 1000 mSec
PORTB &= ~B1; // Set GPIO1 to LOW
Toggle Method
This method takes advantage of a feature found on a limited set of AVR MCUs such as the ATmega328 (it may be used on an UNO or Nano), the ATTiny85 and the ATTiny10. Setting a bit to 1 in the InPut register will cause the corresponding GPIO pin to Toggle state. We save 2 lines of code using this method. Here is the modified loop() function:
void loop() {
PINB |= B1; // Toggle GPIO1
Timer Method
We can initialize the timer to run continuously and toggle B1 every 1000 mSec in the setup() function. The loop function is only there to keep the Arduino IDE happy. This method has the advantage of not using any execution resources. We could put some code in the loop and it would not be affected by the blinking, as if the LED was being operated in the background.
// Let the compiler do the hard work
#if (F_CPU/1000000)<5 // For SYS_CLK < 5 MHz
#define COMPARE F_CPU / 64 // Value to load into OutPut Compare A Register
#define PRE_SCALE 3 // PreScaler option = / 64
#else // For SYS_CLK >= 5 MHz
#define COMPARE F_CPU / 256 // Value to load into OutPut Compare A Register
#define PRE_SCALE 4 // PreScaler option = / 256
#endif
#define B1 2 // LED is on GPIO B1
void setup () {
DDRB = B1; // Set LED pin to OutPut
TCCR0A = 1<<COM0B0 | 0<<WGM00; // Toggle OC0B = GPIO B1 using CTC mode
TCCR0B = 1<<WGM02 | PRE_SCALE<<CS00; // CTC mode using OCR0A;
OCR0A = COMPARE; // ( F_CPU / 64 ); // = 15624 -- 1 second ie 0.5Hz
void loop () {} // just to keep the IDE happy.
Timer with Interruputs - PWM mode
Here we use an interrupt on every compare match to change the PWM Pulse Width to create a repetitive min to max brightness sequence for a "heartbeat" effect.
Defines and ISR routines.
#define PRE_SCALE 1 // PreScaler option = / 64
#define PRE_SCALE 2 // PreScaler option = / 256
#endif
#define B1 2
#define INVERT_mode 2
#define nonINVERT_mode 3
#define OVF_irq 1 // Enable OverFlow IRQ
#define COMPA_irq 2 // Enable CMPA IRQ
#define COMPB_irq 4 // Enable CMPB IRQ
ISR( TIM0_COMPB_vect ) { // We will change the OCR0B value in increments of 128 (80HEX)
if( OCR0B > 0x82 ) { OCR0B -= 0x80; } else { OCR0B = 0x3F80; }
setup() function.
void setup() {
DIDR0 = 0x08; // Disable GPIO on B3 - RST/ADC3
TCCR0A = INVERT_mode<<COM0B0 | 0<<WGM00; // Toggle OC0B = GPIO B1 using PWM mode
TCCR0B = 2<<WGM02 | PRE_SCALE<<CS00; // PWM mode 8 using ICR0 as TOP
ICR0 = 0x4000; // This is TOP
OCR0B = 0x2000; // This value set the PW - here set to 50%
TIMSK0 |= COMPB_irq;
sei(); // enable interrupts
void loop() { } // loop is only here to keep the IDE happy.
So, Register Programming can save us many bytes of Flash and "RAM", but you do have to RTFM.
The DataSheet is located at: ATtiny10 DS.
Sketches are also available on my GitHub.
I couldn't make these boards without the assistance of:
JLCPCB - Trusted by 5.4M Engineers Worldwide! Get High-quality PCB Prototypes for Just $2! Sign up to Get $80 Coupons
They make SMD/SMT a breeze.
