Source code in the bitbucket repo over there
Connect the PS2 pins as described in the sketch, connect a RS232 level shifter to the Serial1 pins on the Teensy / Arduino and the mouse port on the DEC VAX or VT. DEC Mouse pinouts and protocols can be found in the "VCB02 Video Subsystem - Technical Manual" and I will post the relevant info here shortly as well.
Juan M. Casillas
Eduardo Zola
Nikolay Popov
warmbit
Do you have anymore documentation on this one? This has been the best source I have found to try and save some manufacturing equipment. Its turned into a project of interest for me.
