Design by Grant Searle, board by NKK, assembled by me.
View all 8 components
I bought it on eBay: https://www.ebay.co.uk/itm/175882294924
It uses a 68B09P (6809 rated at 2 MHz, with on-chip oscillator), and a 7.7328 MHz crystal.
The UART is a 68B50P (6850 rated at 2 MHz), which has problems with USB-to-serial adaptors made by FTDI due to a bug in the latter's chips.
See https://hackaday.io/project/167418-ftdi-usb-cable-problems-with-6850-acia
It is nothing amazing, just a layout of Grant Searle's minimalist design.
It does have a 40-pin expansion socket, which makes life easier if you wish to add experimental features (which I do).
In particular, I'd like to add a better serial channel device, to replace the 6850.
View all 2 project logs
micl
Craig
WingTechCorner
Michael O'Toole
Yes, delete it Cancel
You are about to report the project "6809 board", please tell us the reason.
