Thanks to Hackaday for the opportunity to share my project here.
That said, I’ve run into a few issues over the past months when publishing new project logs - at times losing a lot of work, including an entire post. I’ve also started to feel that the project log system here can get a bit hard to navigate, and that new posts are easy to miss (I often struggle to find my own posts).
So I’ve decided to move this project over to my own blog and continue documenting the progress there.
The new blog is available at:
https://pleasantsoftware.blogspot.com
I’ve also written a short post explaining what I’m doing and why:
https://pleasantsoftware.blogspot.com/2026/03/setting-up-new-blog-home-for-my-build.html
Thank you, and see you over there…
Zaggo
