2024-05-18
Had a first attempt at disassembling the ROM.
I assumed the 6522 was being used in a clever way to provide a serial interface. Which would probably be a headache to reverse engineer.
The ROM is marked "Autobaud" so there should be some serial I/O going on. But looking at the board, there are no RS232 buffers.
Looking at the code, some of it tests bits 1 and 0, which are status bits in the 6850, so maybe it is using 6850 chips on an separate board?
That's all the work I fancy doing today. I think buzzing-out the signals going to the PAL and the PROM chips may give further clues to the memory mapping.
