Finally, after much tests, there is the result, a board that get the 8 bits serial informatin from the controller and shows it as one byte, all the 8 bits at a time, for the Z80 CPU at the ports E0h and E1h, the Z80 just need to read it and all the pressed keys will be there. I will update the schematic with some other changes, like IO addresses and some expansion slots pins changes.
