SamD21 card development platform
with 22x5 led matrix display,
sd card, battery, environment sensors
main.pyTest script to flash onboard RGB ledpy - 220.00 bytes - 03/07/2017 at 14:48 |
bom.txtbom exprotedplain - 7.52 kB - 03/06/2017 at 23:08 |
PYcARD.schSchematicsch - 1007.21 kB - 03/06/2017 at 22:33 |
PYcARD-RTM.brdBoard with display for factorybrd - 329.05 kB - 03/06/2017 at 22:33 |
firmware.binadafruit-circuitpython-arduino_zero-0.9.1.binoctet-stream - 180.10 kB - 03/06/2017 at 22:33 |
Assembly board ...
solder all components
Burn bootloader ...
it is easy, just connect atmel ICE,
run arduino IDE and click on ...Burn bootloader
Now you have Arduino zero compatible board, you can upload display test demo
Install Circuitpython ...
Download circuitpython release
rename file to firmware.bin
press twice reset button to activate bootloader
run this command
bossac -e -w -v -b firmware.bin
press reset ... now you have new drive in computer ...
copy main.py file ... RGB LED start red flashing :)
People have asked us to create a wearable biometric data gathering device (see our philometer project) and this board would be really fun to build around. Nicely done!
Is there any description for how to make this project ??? I can't understand how can we make it .
Boards on way, soon as posible I assembly and post more info.
Very interesting project.
Have you any idea of how much this board will cost?
about 100$ 20pcs ....20$ for 2mm, 20$ ENIG, 25$ steel stencil (soldering lot of led without reflow is suicide ) and rest is for boards. Boards shipped and awaiting soon delivery :)
What is this ridiculous site format? Can't make head nor tail of it...
Ridiculous site is (and always has been) ridiculous. Can't figure out if it's the summer intern or a big committee to blame.
where did u buy the atsamd21g18?
