Hoarders Active Load
An active load built out of scrap, jellybean, cheap and salvaged parts
So your at a point where you think: "Blimey! When the hell did I accrue so much stuff!?" and your running out of space for important things: like the the bazzilion prams the other half is collecting! You've spent too long collecting stuff to warrant throwing it out...SO YOU BUILD!
This is a simple project that has been done to death by countless before me: an active load.
However I'm using the mantra of only using parts I've collected, salvaged and only when I've absolutely had to: bought of places like eBay, Banggood, and the like.
The design criteria is simple build an active load that'll fit into the selected enclosure and try and get it you sink as much power as possible! No holds barred! If it fits or I can find it in my stock pile or get it for next to nothing on the slow boat from china, its game!
However, one restriction: NO MCU/ARM/Arduino or anything like that, purely analogue control. Why? cos I'm old school and it's t
As mentioned the aim is to build a active load out of salvaged parts and the like. But this has also got a purpose to serve. I have some 18650 cells that need testing and in order to know what capacity they are I'm going to charge them up and load test them to verify their capacity.
This is also a learning experience. I believe that the only way for things to stick in any engineering discipline is to design, test, fail, fix, build, test, fail, fix, finish and fix for the rest of your life!
Basically I've known the modus-operandi of this circuit since first looking at it and have always wanted to build one and now I have collected enough parts to do it, its time to knuckle down!
Some Specifications - here's is what I know I want, these will be subject to change depending on resources.
Electrical/Instrument specifications
CriteriaMaxTyp.Min.
Load Instrumentation
input load voltage (V DC)3230
Load Max Current (A) - depending on resources5A3A
Load Max Power (W) - depending on resources12060
Current resolution (A)- depending on resources0.0010.01
Current Accuracy - depending on resources1%2.5%5%
Display resolution4-digit3-digit
Display Accuracy1%5%
Load Current overshoot5%
Load current Settling time (ms)1
Load current rise time (ms)0.5
Power supply
Circuitry Supply voltage (V DC)1512
Supply Input Voltage (V AC)240110
Main supply Power(W)10
Electronics supply current (A)20.5
Safety
Safety Class2
Mains side input fuseFitted
Features
CriteriaMust HaveWill haveNice to HaveResource dependant
Power on indicatorY
Load active indicatorY
Mains input protectionY
load input OV indication/protectionYY
Max load power indication/protectionYY
Front panel mains switchY
Voltage/Current displayY
Dual Channel CapabilityYY
multi-turn adjustment potY
Load output on/off switchY
Complete Load Isolation when load offY
IEC inlet for ease of portability and installationY
Active cooling for LoadY
Temperature controlled active coolingYY
standard 3/4" spacing of 4mm binding postsY
USB Load portY
External control signal inputYY
Capacity Reading/DisplayY
Silent active coolingY
  • 1 × Enclosure deed big enough for this project
  • 1 × Red indicator LED
  • 1 × Green indicator LED
  • 1 × Power rocker switch
  • 1 × power supply (>12VDC) preferably mains supplied
View all 15 components
  • Project re-opened and some changes
    Tron9000 • 07/30/2019 at 13:17 • 0 comments
    So after a year or 2 sat on a shelf, I’ve made a start on construction of this project and some changes to its design.
    Currently I’m in the middle of sorting out my junk in preparation for an impending move. As such I’d like to actually use up some parts for projects gathering dust, and sharpish!
    So I’ve...for want of a word...throw the fine details of the spec out of the window, making the design more simple and concentrating on completing this project. Am currently re-doing the schematic, but in the mean time I’ve actually bolted everything to the front panel of the box.
  • How goes it up to now
    Tron9000 • 01/26/2017 at 22:22 • 0 comments
    <thumbs note book>
    OK, so I've start this project before submitting it. Best bring it up to date...
    Firstly I got myself a beefy heatsink (one that was supplied with an AMD Phenom2 I bought ages ago) that would fit into the enclosure and drilled and tapped 2 holes for 2x D1047 transistors (like 2n3055) and mounted them onto it with some thermal paste.
    Why accomodate 2? well just in case I wanted more amps!
    I then built up the circuit I intended to use:
    Using another bench supply as a load and running my circuit off a separate 5V supply, it worked as I expected. However, 2 things were an issue:
    1. Using a 1R resistor: it was getting hot
    2. the bench supply I was using for load could only do 2.2A - I needed a beefier supply - I managed to dump 60W though!
    3. The heatsink had a fan on it and I'd like to use it! The pass transistor was getting hot enough to not bear touch it (which is roughly 60 degC or so)
    In short I wanted MORE!
    SO i swapped the 1R out for a 0R1 resistor.This made things very sensitive! For every 100mV on pot meant 1A through the Pass transistor. However the resistor was not getting hot now cos P=IV=1*0.1=100mW rather than the 1W as before.
    I then started on modifying the wiring on the fan on the heatsink and ran it off the 12V line off the same power supply I was running the electronics off (for those interested: its an old farnell TOPS2 power supply).
    However the heatsink unit was a bit unsteady on the bench when placed fan side up, So I decided to drill and tap 4 more holes in each corner of the heatsink so I could stand it on the bench...
    ...well that's buggered it!
    I was able to remove the broken tap and there was enough thread to screw in an M3 screw and was able to place it on the bench with out wobbling about.
    I then butchered an old ATX power supply that could deliver 17A on its 12V rail. Tis was going to test the amount of current I could pull.
    With this setup I managed to pull a little over 5A @ 12V = 60W again. with a slight modification to the circuit I was able to pull nearly 10A for about 5 seconds, but got scared and didn't want to break things just yet. The Heatsink was nice and cool @ 60W now.
    Now the keen eye'd amongst you will see that the buffer transistor on the breadboard has changed from to-220 to to-92. Whilst modifying the circuit I found the TIP31 was getting warm and whilst removing it I thought that this part of the circuit was a bit poorly designed. So I changed it for a 2n3904 and stuck a 22R resistor as a base resistor to the pass transistor. I also put a 33k resistor in series with the setpoint pot so I got a sensible amount of rotation on the pot.
    So Whats next?
    1. I want to see the transient response of the current on this circuit and if needs be calculate a suitable feedback network to avoid any overshoot.
    2. select components and build a reference circuit
    3. Implement a new pair of heatsinks I've found:
    4. Even though I don't doubt that they could handle 60W, I'd like to determine their thermal resistances.
    Right...you're up to date now!
View all 2 project logs
