Desired features:
chilled water
hot water
small double sink
fresh water tank
waste water tank
Chilled water options:
ice
small refrigeration unit
circulate water through a small radiator with a fan.
Hot water options:
electric kettle
boil by the pot
draw engine heat somehow
black water pipes on roof with pump
on demand water heater
Sink Options:
camper sink, stainless steel
plastic camper or mobile home sink
full size single sink
Water Tanks:
limited to 5 gallons for weight
stored behind wheel arches in otherwise wasted space
vented
quick disconnect hoses with cut off valves
No Shower:
too large and messy.
can wash from the sink
Gym membership.
Desire
