Stringing demonstration video
Functions
- LB/KG display and setting
- Pre-Stretch function
- Constant-Pull system
- Knot function
- Tension adjustment manually during tensioning
- Tension calibration
- Stringing timer
- Tension timer
- Tension counter and boot counter
- Detailed recording of tensioning logs
- Pull speed with 9-speed selection
Features
- 0.05LB High Precision
- Achieved with the Sparkfun HX711 at 94Hz and software version V2.2 and later.
- DEMO Vides
- Low Power Consumption
- Uses a DC19V4A power supply. *
- Real-time UPS Redundancy (Uninterruptible Power Supply)
- Uses 5 x 18650 batteries to ensure at least one complete racquet stringing.
- Compact and Space-Saving
- Dimensions are approximately 38(L) x 15(W) x 9(H) CM.(excluding clamp head)
- Simple structure, low cost, and easy maintenance
- All components are easy to source and inexpensive
- High durability
- Over 1 million tension reliability test cycles have been completed with no hardware failures detected. 1 Million Cycles Video
Function demonstration video
Main Hardware
- Raspberry Pico H
- CBX/SGX 1610 ballscrew 200MM sliding table
- NEMA23 57x56 stepper motor (2-phase 4-wire 1.8° 1.2Nm)
- TB6600 stepper motor driver
- NJ5 20KG load sensor (YZC-133)
- HX711 module (SparkFun)
- 2004 i2c LCD
- Wise 2086 bead clip easy head
- Five-way key module
- Button
- Micro switch
- Active buzzer (active high trigger)
- Tri-color LEDs
- An unregulated UPS battery box made of 5 18650 batteries.
Wiring Diagram
The process of making a condensed version.
