So! Committing to this challenge.
Let's start with the WHY: well. that's a challenge, and I've got a couple of things I've always wanted to try out:
- Sculpture, easy to assemble
- Couple of touch points
- Contains a MUD of sort
- Thin, because, well.. business case
The WHAT is easy:
- A space where people explore their contact.
- A nice looking card, electronic sculpture like
- Possibility to encase it in epoxy
The HOW around a couple of topics:
- Energy: I've thought NFC, Solar, .. but going for another approach definitely ;)
- Heart: ESP32 is relatively stable. There were a couple of NFC chips but I don't have bandwidth to play with them.
- IOs: Visuals: array of leds is tough. A small OLED screen should do the trick.
Hackaday contraints:
- Wafer thin; let's keep it thin-ish. The usb plug might be the bigger part
- Aesthetics: yeah, definitely
- Cheap: let's go for off the shelf, aliexpress components
- Fun and games: having a toy: definitely if / with a MUD.
- Utilitarian: see the above =)
Rules:
- Form factor: around 90x50mm - fits in a pocket
- Do a bit more than traditional business card: yup
- Documenting: that's what we do.
- Design: won't be much design files, but documenting should do the trick.
kelu124
