“The Cyber Clock” A rechargeable battery-powered 1.51-inch transparent OLED clock with accurate internet time and date. It can also measure your room temperature and humidity from an onboard sensor. It can show the battery percentage as well, with a fully 3D-printed Cybertruck body. It also comes with rollable wheels so you can play with it. It is also possible to lock the wheels by tightening screws so it wouldn't fall from the desk by accident !.
I took inspiration from Flipper Zero UI elements to design this watch head
Through these instructables, we will learn how to build one yourself and customize it to your time zone. so let's get started with the cyber clock build.
Supplies
Part
- Seeed Studio XIAO ESP32C3
- DHT11 Humidity & Temperature Sensor
- 1.51inch Transparent OLED
- Slide switch
- 500mah 3.7v battery (identical battery with 600mah)
- 30awg wires
- 3*10k Resistors( you can use both SMD type or through hole Resistorsfor it .iam using smd 0805 Resistors)
- 6*CSK Allen M3 x 10mm Screws
- B-7000 Multi-Purpose Glue
- Super glue
- Kapton tape 10mm
Tools
- Allen key
- Soldering iron
- Wirecutter
- Glue gun
Used 3D printer
Used 3D printing filaments
Step 1: Modeling in Autodesk Fusion 360
I used Fusion 360 to plan and design my project. I design this project with 2 things in mind, one easy-to-assemble and the other easy to 3d print. I broke down the body of the project into several pieces for this purpose. By importing accurate models of electronic components I was able to predetermine the position of the components and modules on the body. so I was pretty sure that everything would fit and work together even before I built the prototype. That saved a lot of time and effort. all design files are given below
Step 2: 3d printing
After exporting all models into.STL files. I 3d printed it using my Anycubic printer. I had to use 3 different colour PLA filaments for this project, Black, Gary, and white. You can find .stl files from step 1. The top body needs some support material when you print.
Step 3: flashing code to Xiao esp32c3
I always like to upload the code to the microcontroller before assembly. I am using Arduino IDE for flashing the code. follow these tutorials for setting up IDE for Seeed Studio XIAO ESP32C3 and learn more about this board
Make sure to install all required libraries into Arduino IDE
libraries for DHT11
How to install library tutorial video link
How to set your wifi password
We need to have an internal connection to get time data from NTP servers . so we need to connect this clock to your wifi network. you can enter your wifi credentials on 46,47 lines
const char* ssid = "ssid";
const char* password = "password";
How to set your time zone
The time zone is configured using your GMT offset in seconds. My GMT off-set is GMT +5:30 , now we need to convert it into seconds which is 19800sec. Just google it for easy conversion
You can enter your GMT offset in seconds in line 65 of the code
NTPClient timeClient(ntpUDP, "pool.ntp.org", 19800, 0);
The complete code
#include <WiFi.h>
#include <SPI.h>
#include <NTPClient.h>
#include <WiFiUdp.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <DHT.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
#define ANALOG_PIN D1 // Analog pin connected to the voltage divider
#define ADC_MAX 4095 // 12-bit ADC
#define REF_VOLTAGE 2.8 // Reference voltage of ADC (3.3V for Xiao ESP32C3)
// WiFi credentials
const char* ssid = "ssid";//your ssid
const char* password = "password";//your wifi password
// OLED display SPI pins
#define OLED_MOSI D10
#define OLED_CLK D8
#define OLED_DC D4
#define OLED_CS D7
#define OLED_RESET D5
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT,
OLED_MOSI, OLED_CLK, OLED_DC, OLED_RESET, OLED_CS);
#define DHTPIN D0
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
// NTP client to get time
WiFiUDP ntpUDP;
//bit ui bitmap
static const unsigned char PROGMEM image_paint_1_bits[] = {0x60,0xf0,0x90,0x90,0x90,0x90,0xf0};
static const unsigned char PROGMEM image_paint_0_bits[] = {0x7e,0x3f,0x3f,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfc,0xfc,0x7e,0xc1,0x3e,0x40,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x02,0x7c,0x83,0xd5,0x3c,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x3c,0xab,0xd5,0x39,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x9c,0xab,0xd5,0x32,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x4c,0xab,0x95,0x24,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x24,0xa9,0x25,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x10,0xa4,0x49,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x92,0x93,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0xc9,0xa6,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x65,0xac,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x35,0xa8,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x15,0xa8,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x15,0xa8,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x15,0xa8,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x15,0xa8,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x15,0xa8,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x15,0xa8,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x15,0xa8,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x15,0xa8,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x15,0xa8,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x15,0xa8,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x15,0xa8,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x15,0xa8,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x15,0xa8,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x15,0xa8,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x15,0xa8,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x15,0xa8,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x15,0xa8,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x15,0xa8,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x15,0xa8,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x15,0xa8,0x26,0x04,0x92,0x48,0x3f,0xff,0xff,0xff,0xff,0xfc,0x12,0x49,0x20,0x64,0x15,0x88,0x29,0x09,0x24,0x90,0x7f,0xff,0xff,0xff,0xff,0xfe,0x09,0x24,0x90,0x94,0x11,0xa8,0x29,0x12,0x49,0x20,0xf0,0x00,0x00,0x00,0x00,0x0f,0x04,0x92,0x48,0x94,0x15,0x88,0x26,0x24,0x92,0x41,0xe0,0x00,0x00,0x00,0x00,0x07,0x82,0x49,0x24,0x64,0x11,0xa8,0x10,0x00,0x00,0x03,0xff,0xff,0xff,0xff,0xff,0xff,0xc0,0x00,0x00,0x08,0x15,0x88,0x0f,0xff,0xff,0xfc,0x00,0x00,0x00,0x00,0x00,0x00,0x3f,0xff,0xff,0xf0,0x11,0xa8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x15,0x88,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x11,0xa8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x15,0x88,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x11,0x28,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x14,0xa8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x15,0x28,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x14,0xa8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x15,0x28,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x14,0xa8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x15,0x28,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x14,0xa8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x15,0x2f,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,0x01,0xff,0xff,0xff,0xff,0xff,0xff,0xf4,0xa8,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x15,0xa8,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x15,0xa8,0x00,0x80,0x00,0x00,0x00,0x00,0x02,0x08,0x20,0x00,0x00,0x00,0x00,0x00,0x15,0xa8,0x01,0xc0,0x00,0x00,0x00,0x00,0x01,0x10,0x50,0x00,0x00,0x00,0x00,0x00,0x15,0xa8,0x02,0xe0,0x00,0x00,0x00,0x00,0x00,0xa0,0x50,0x00,0x00,0x00,0x00,0x00,0x15,0xa8,0x03,0xe0,0x00,0x00,0x00,0x00,0x00,0x40,0x50,0x00,0x00,0x00,0x00,0x00,0x15,0xa8,0x05,0xf0,0x00,0x00,0x00,0x00,0x00,0x40,0x50,0x00,0x00,0x00,0x00,0x00,0x15,0xa8,0x05,0xf0,0x00,0x00,0x00,0x00,0x00,0x40,0x88,0x00,0x00,0x00,0x00,0x00,0x15,0xa8,0x03,0xe0,0x00,0x00,0x00,0x00,0x00,0x40,0xf8,0x00,0x00,0x00,0x00,0x00,0x15,0xac,0x01,0xc0,0x00,0x00,0x00,0x00,0x00,0x40,0xf8,0x00,0x00,0x00,0x00,0x00,0x35,0xa6,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x40,0x70,0x00,0x00,0x00,0x00,0x00,0x65,0xa3,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x40,0x00,0x00,0x00,0x00,0x00,0x00,0xc5,0x91,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x40,0x00,0x00,0x00,0x00,0x00,0x00,0x89,0x49,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x40,0x00,0x00,0x00,0x00,0x00,0x00,0x92};
float readBatteryVoltage() {
int analogValue = analogRead(ANALOG_PIN);
float voltage = (analogValue / (float)ADC_MAX) * REF_VOLTAGE;
// Voltage divider scaling
voltage = voltage * (10.5 + 10) / 10.0; // (R1 + R2) / R2
return voltage;
// Function to calculate battery percentage
float calculateBatteryPercentage(float voltage) {
float percentage;
// Assuming a linear relationship between voltage and percentage
if (voltage >= 4.2) {
percentage = 100.0;
} else if (voltage <= 2.5) {
percentage = 0.0;
} else {
percentage = (voltage - 2.5) / (4.2 - 2.5) * 100.0;
return percentage;
void setup() {
// Start serial communication
Serial.begin(115200);
dht.begin();
analogReadResolution(12); // Set ADC resolution to 12-bit
// Initialize OLED display
if(!display.begin(SSD1306_SWITCHCAPVCC)) {
Serial.println(F("SSD1306 allocation failed"));
for(;;); // Don't proceed, loop forever;
//display.display();
// Connect to Wi-Fi
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED) {
delay(1000);
Serial.println("Connecting to WiFi...");
Serial.println("Connected to WiFi");
// Initialize time client
timeClient.begin();
void loop() {
// Update time from NTP server
timeClient.update();
unsigned long epochTime = timeClient.getEpochTime();
struct tm *ptm = gmtime ((time_t *)&epochTime);
int monthDay = ptm->tm_mday;
int currentMonth = ptm->tm_mon+1;
int currentYear = ptm->tm_year+1900;
int currentHour = ptm->tm_hour;
int currentMinute = ptm->tm_min;
int currentSecond = ptm->tm_sec;
float batteryVoltage = readBatteryVoltage();
float batteryPercentage = calculateBatteryPercentage(batteryVoltage);
// Get temperature and humidity
float t = dht.readTemperature();
float h = dht.readHumidity();
// Convert time to 12-hour format
String period = "AM";
if (currentHour >= 12) {
period = "PM";
if (currentHour > 12) {
currentHour -= 12;
} else if (currentHour == 0) {
currentHour = 12;
// Display data on OLED
display.clearDisplay();
display.setTextColor(SSD1306_WHITE);
// Display time
display.setCursor(19,6);
display.setTextSize(3);
if (currentHour < 10) display.print('0');
display.print(currentHour);
display.print(':');
if (currentMinute < 10) display.print('0');
display.print(currentMinute);
display.setTextSize(1);
display.setCursor(108, 39);
display.print(period);
// Display date
display.setCursor(36, 39);
if (monthDay < 10) display.print('0');
display.print(monthDay);
display.print('/');
if (currentMonth < 10) display.print('0');
display.print(currentMonth);
display.print('/');
display.print(currentYear);
// Display temperature
display.setCursor(79, 53);
display.print(t);
display.print("C");
// Display humidity
display.setCursor(22, 53);
display.print(h);
display.print("%");
display.drawBitmap(0, 0, image_paint_0_bits, 128, 64, 1);
display.setCursor(14, 39);
display.print(batteryPercentage,0);
display.drawBitmap(8, 39, image_paint_1_bits, 4, 7, 1);
display.display();
// Delay before the next update
delay(1000);
Step 4: Wiring Diagram
It seems like the wiring is a little complicated right? but just follow the colours of the wire connection and the labels on the endpoints. also, the wire colors used on the driver board and schematic are the same So grab your tools let's start the build
Step 5 assembly and wiring
We can start by creating a voltage divider in the back side of the Xiao
Step 5.1
First, we need to put some Kapton tape under the Xiao battery terminate
Step 5.2
Solder the 10k SMD resistors to the two battery inputs. Then, connect the other ends of the resistors to the D1 pin using a small gauge wire to measure the battery voltage.
Step 5.3
Connect the positive terminal of the battery to one of the terminals of the power switch, and connect the other terminal of the switch to the BAT+ of the Xiao. Also, connect the negative terminal of the battery directly to the BAT- of the Xiao. also, make sure that all the wires are at the proper length by placing them in the underframe
Step 5.4
Glue the battery, xiao, and power switch using glue. I already designed slots for the components to fit in. Make sure to get the wire under the xiao through the gap.
Step 5.5
Cut the terminals of the DHT11 to the appropriate length. Solder a 10k resistor between the VCC and DATA lines of the DTH11. Also, solder 3 wires to VCC, GND, and DATA with the length that can reach the Xiao pins. I am using a through-hole 10k resistor here
Step 5.6
Place the DHT11 upside down into the small window. Now, glue the DHT11 using our B-7000 Multi-Purpose Glue. (We are not using hot glue here because the heat might damage the sensor.)
Step 5.7
Solder the DHT11 sensor wires into Xiao, Also I did some wire management with Kapton tape. now we are done with most of the work on the down frame let's move on to the upper body
Step 5.8
Be very careful during this step as we install the OLED screen into the main body. Do not apply too much pressure when handling the display, as it can easily break. We will be using B-7000 Multi-Purpose Glue to attach the display to the 3D print. Make sure that the orientation of the display is correct.
Make sure to check the orientation of the flex cable when you test the display with the driver board.
apply glue to the inside, bottom, and left and right corners of the frame. Don't use too much glue it will spill from the edges
gokux
