APC Semi-Patchable SynthCard
Classic Atari Punk Console with a 556 Core and 555 timer L.F.O in a portable Format for all your Buzzing Needs
Starting from
has orders / reviews
Ships from
Low Parts for a good Starter Project for Learning How to Solder. This Portable Noisemaker with Built-in Speaker and 3.5mm Sound Output Jack lets you craft a unique sound.
The Classic Vintage Atari Game Console sound has a new life with Light Sensitive world. Allowing the Flowers to Guide the Growing sound and Timbre of Low Wavy Goodness.
Switch Between the Gritty low Bit Crushing APC and add Timbre with the Switchable LFO. Make it Drone or Use it as a Button Mashing Bit Crusher.
Take it to the Next level and use small jumpers to patch Between the Semi-Patchable card Punk CV, LFO CV, L.F.O Output, APC Output for those other Noisy opportunities.
Subcircuits
•1 x 556 Timer(multivibrator oscillator + monostable mode)
•1 x 555 Timer (LFO)
• Classic Atari Punk Console with a 556 Core and 555 timer L.F.O
• Atari Smash Button for those moments of gritty smashing
• Drone Switch for Some constant BUGGY BEE BUZZing
• LFO Switch Low Frequency Oscillator Switch for some extra modulation
• *Optionally* Semi-Patchable with Punk CV, LFO CV, L.F.O Output, APC Output
• Dip Switch Light Controlled Pitch, PulseShaper, LFO Frequency.
• Built in Battery and PCB speaker for On the go noise sessions.
Schematic_Punk-Console-Business-Card-v1.3.1_2024-03-10.pdf
Adobe Portable Document Format - 74.96 kB - 05/23/2024 at 05:11
Preview
Atari Punk Console SynthCard Build Document V1.3.2.pdf
Easy to Follow Printable Build Document
Adobe Portable Document Format - 6.92 MB - 05/23/2024 at 04:36
Preview
  • 1 × 555 Timer IC
  • 1 × 556 Timer IC
  • 2 × 1k Electronic Components / Misc. Electronic Components
  • 2 × 100k Electronic Components / Misc. Electronic Components
  • 1 × 2.2k Electronic Components / Misc. Electronic Components
View all 21 components
View all 6 project logs
  • 1
    Building Instructions APC Semi-Patchable Synth_Card
View all instructions
