Assembly
A project log for SOS Business Card
Business card that generates Morse code SOS signal using discrete logic components.
martynasMartynas 06/21/2024 at 09:510 Comments
PCBs finally arrived.
Noticed some issues while soldering:
I  have soldered two PCBs. One powered by coin battery and driving small green LED.
Another powered from USB-C and driving brighter white LED with possibility to connect external load.
Board thickness is 5.7mm (PCB 1.2mm + TO-220 4.5mm).
