Uberlogger datalogger
The Uberlogger is a stand-alone voltage and temperature logger with Wi-Fi connectivity that logs for days
0 followers
The Uberlogger data-acquisition system is a simple, yet powerful high-performance logging device. It can log 8 analog channels and 6 digital inputs in CSV format directly to an SD-card. You can select the analog channel as either analog input or temperature input using an NTC temperature sensor. This way you can measure voltage and temperature simultaneously. The resolution can be set as either 12-bits or 16-bits and has a sample frequency ranging from 1 Hz till 250 Hz. The Uberlogger is configured through the web-based user interface which you can connect to through Wi-Fi, either using its hotspot functionality or through the client mode, which allows you to connect the Uberlogger to your own access point.
Key features
  • 8 analog channels which can be used as either voltage inputs or NTC inputs
  • 6 digital inputs
  • Log frequency: 1 Hz – 250 Hz
  • Voltage range: +/- 10V or +/- 60V
  • Resolution: 12- or 16-bit
  • Connect with Wi-Fi: 2.4 GHz hotspot or with your 2.4GHz Wi-Fi access point
  • Live data view and control using the online interface
  • REST API control for remote control of your logger
  • Includes 1x USB-C cable, 1x 32GB SD card and 8x NTC sensors
  • Firmware upgradable for new features
Specifications
ParameterSpecification
Supply voltage4.75 V – 5.25 V
Supply current (max)300 mA
Typical power consumption850 mW
InterfaceWi-Fi, SD-Card
Analog inputs8
Analog input voltage-10 V/+10 V or -60 V/+60 V
ADC sample rate1 Hz – 250 Hz
ADC Resolution12, 16 Bit
NTC type10 KΩ
Digital inputs6
Digital input voltage-60 V/+60 V
Dimensions145 x 77 x 23 mm LxWxH
  • 1 × ESP32-S2
  • 1 × STM32G030
  • First finished version...more features coming
    Paulus Potter05/29/2024 at 08:21 0 comments
    I have finished my first version which I sell on my Tindie store. I still have some things I would like to improve:
    - A good 3D printed enclosure (maybe for a DIN rail as well?)
    - Wider sample range (<< 1 Hz and >> 250 Hz)
    - Trigger functionality
    - Timer functions
    - Output control
    - NTP server
    - Streaming API
    - MQTT and Home assistant support
    Maybe you have suggestions?
View project log
